dirty noise using d...
dirty noise using djcontroller instinct
hi all!!
i am having some troubles with my instinct controller while playing or mixing tracks. speakers are connected with the controller via aux. and my headphones are connected to the controller as well, i use traktor pro scractch 2 mapped through the hercules official file. when i play some track both through speakers and/or headphones the music sounds with some dirty / interferences sound.
some spanish users have experienced the same problem: http://www.herculesdjmixroom.com/en-gb/forum/es-primeros-pasos-en-djing-por-ordenador/012501/
would really appreciate some help!
The following documents will propably help:
http://ts.hercules.com/faqs/eng/her_eng_00446.pdf
Thanks! As soon as I try the instructions I will let u know!
