dj conroll air ir s...
dj conroll air ir sensor
i have not worked ir sensor, after updating the drivers, using windows 7 64 bit .... please help
Did you make sure the proximity sensor is enabled in the DJ Control panel ?
Yes everything is okay included everything from what else might be, please tell us
I have the same problem!the proximity sensor is enabled the leds are working fine but there is no effect change at all!!
A) Please complete your profile here
   - Complete the field: Hercules Equipment In Use
/* Style Definitions */
table.MsoNormalTable
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-priority:99;
mso-style-parent:"";
mso-para-margin:0cm;
mso-pagination:widow-orphan;
font-size:10.0pt;
mso-fareast-language:EN-US;}
   - Complete the field: Software In Use
   - In the field: Describe Your Equipment, precise
       - your operating system (for example Windows 7 64-bit Service Pack 1),
       - your computer model, CPU and RAM
       - your versions of your software and of DJ Control Air driver.
B) Please describe your situation: which effect have you loaded, please confirm that you don't see the effect knob mmoving on the screen.
