dj console not work...
dj console not working with newest macbook pro
my mk4 does not work with my macbook pro. i have the latest drivers for traktor and vdj installed. when i plug my console in and open one of the programs some of the lights on the console turn on but that is it. i press a button and it does not work. when i use the midi audio setup on my mac it reads it and everything so it is something with the software with the console. what is wrong?
There is indeed a known issue between the MK4 and the new MacBook. A new driver and firmware will be issued soon to correct the problem.
However, in the meantime, you can use a powered USB hub between the console and computer to prevent this problem.
Okay thank you I will try that out!
Hello JuWi404,
The powered USB hub needed is a USB 2.0 USB hub.
I ordered this one off Amazon:
http://www.amazon.com/Belkin-USB-2-0-4-Port-Ultra-Mini/dp/B000Q8UAWY/ref=sr_1_1?ie=UTF8&qid=1350465466&sr=8-1&keywords=usb+hub
It comes tomorow or the next day.
Hello. I´m having the same problem in my mid2012 MBP
I allready have a hub but I don´t know if it is powered. How can I know that?
Another quetion is, when will the drivers be updated? Are they Apple Drivers or Hercules drivers??
Write A.S.A.P
Thanks
The new drivers correcting the problem, have been available since the end of October:
  http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=262&cid=1
For future reference, a self-powered USB hub comes with his own power supply, where a bus-powered hub relies on the power provided by the USB port, and does not include a power supply.
