dj hercules mp3 e2 ...
dj hercules mp3 e2 help needed please!
hey everyone,
i need some help setting up my dj hercules mp3 e2 with my laptop. two questions really, whats the best software to use with it. and also how do i set it up so i can preview it through my headphones and then feed it out to the speak. do i need a external soundcard and if so what do i need to do with it.
thanks in advance!
Picking the best DJ software is really a matter of personal choice, based on the look of the interface, the workflow and some features you might prefer. I would suggest starting with the provided software and download a few demo of other softwares to give them a trial run.
http://ts.hercules.com/faqs/eng/her_eng_00453.pdf
As for the second question, in order to have both headphone preview and speakers output, you need a soundcard that has at least two stereo output. Since this is not the case for most laptop, an external soundcard will most likely be necessary.
Here is an example of how to configure the Hercules Muse Pocket USB with Virtual DJ:
http://ts.hercules.com/faqs/eng/her_eng_00401.pdf
The configuration would be similar with most DJ software and other multichannel USB soundcards.
Cheers! That is very helpful and much appreciated!
