djuced does not det...
djuced does not detect controller, help please.
hello,
i have a universal dj hercules controller.
i have changed laptop and now dj uced does not detect the controller, i only have a demo or licensed option.
is this normal?
what can i do to fix it?
in my old laptop i never had this problem, the controller always detected me.
thanks
Welcome to the forum.
1) Please complete your profile with technical information on your device in My Space > My Profile in "Describe your equipment", describe your computer
  • brand and model
  • CPU
  • RAM
  • Type of USB port
  • version of DJ software (Eg. Djuced 5.1.3)
2) If you have installed Hercules DJ drivers, can you call the DJ control panel and check if it detects the controller like that:
If you can read a firmware version number, it means the controller is properly detected.
PS) I have read your message on
https://www.herculesdjmixroom.com/es/forum/es-software/032308/
a) it is not good to post twice the same message, as it make a message which will get no answer, please post a message only once.
I will delete the spanish message as I have started answering to this message here.
b) as you post in spanish, should I suppose you are not from Iceland?
