18/07/2019 3:20 pm
hi,
i am having a problem with the djuced pc software that comes with hercules universal dj.
some of the fx in djuced like "fade to grey", "transdelay", "hp filter", etc do not affect the audio on the headphones output. these are only affecting the master output.
so, when i enable a "transdelay" fx and listen on the headphone output, there is no change in audio, but the master output has an audio change.
fx like "gate", "flanger" are affecting both headphones and master output.
this looks like a bug or is this a feature, can someone please confirm? if it is a feature, an explanation would be very helpful why certain fx dont work on the headphone output.
i am using djuced 4.0.7 on windows 10 64 bit. i use the mix knob to listen to the master output on the headphones, instead of actual speakers.
