djuced + hercules i...
djuced + hercules impulse 500 + hercules p32
hello !!!
can i use , at the same time , hercules impulse 500 and p32 with djuced ?
and if this is possible ,
there is a guide somewhere ? sorry for my english
tks!
withwithwithyou can use at the same time
Yes, this is possible. DJUCED includes a sepcial mapping for the P32DJ that expends control layout (instead of simply doubling them).
All instructions to proceed are here:
https://www.herculesdjmixroom.com/en-gb/blog/p32dj/control-djuced-40-with-2-dj-controllers/
The instructions and screenshots might be a bit different since this tutorial was done with DJUCED 40, but the setup is the same.
thanks mr. for your reply !!!
but in the list of supported controllers there isn't my impulse 500 ....do you think it's okay anyway ?
and above all ....
do you think that with the HERCULES P32 I can control the effects of all four Decks(a,b,c,d)?
thanks for the quick answer !!!
Yes, it works with the Impulse 500. As mentionned, the instructions dates from way before this controller was released, but it does not really matter as its really the P32DJ mapping that is different as a secondary controller.
As for what is exactly controlled, sample deck C and D and the corresponding effects, for sure. Maybe there was some modifications to the mapping since, but I'm not sure.
