djuiced + dj instin...
djuiced + dj instinct controller volume issue
hi.
using windows 10 and the audio of any track is expanded to almost (and is some cases is) distorted volume and even with turning down the system volume or the volume of the unit the sound wave is still too loud.
i cannot find any cause in the settings, anyone got any ideas? it was fine with windows 7. ran the program in compatibility mode but still no joy.
thanks
darren
Hi !
You don't put the GAIN knobs at maximum value ? Or the EQ's ?
Please complete your profile in clicking on "MY SPACE"> "MY PROFILE": you have 3 fields to list your equipment:
- In "HERCULES EQUIPMENT IN USE", please check DJControl Instinct,
- In "SOFTWARE IN USE", check your Djuced ,
- In "HERCULES EQUIPMENT IN USE": describe
 .your computer brand and model, CPU, quantity of RAM,
 .your version of Windows 10 : Pro or Home, which update (to know it Start button icon Windows button > Settings > System > About),
 .your DJControl Instinct driver package: is it the last one, 2015_HDJS_6?
 .your version of DJuced 18 software, is it the last one, Djuced 18 1.0.99?
