hi as the post header asks!
are all the led/buttons on the hercules rmx supposed to light up when pressed? im brand new to the rmx and thought they shouldve/wouldve done!
when im pressing the the the eq kills or the 1 to 6 effect buttons then im a little sad that they dont light up. just wanted to ask to make sure this is how it should be and not something wrong with installation or something..
regards
mark
not all buttons have leds.
when you connect the console to the computer, all the leds will blink for a few seconds, so its easy to see which ones have and which ones dont.
cheers dj phatso! at least saves me worrying if the units working correctly. wish it did them all though! never the less ill just have to remember which ones ive pressed on the eq kills!
regards
mark
hello fruity dj,
on dj console rmx, 16 buttons can light on:
2 x pitch reset
2 x beat lock
2 x sync
2 x cue select
2 x cue
2 x play
1 x mic on/off
1 x source 1
1 x scratch
1 x source 2
thanx maxdjack
Not all buttons have LEDs.
When you connect the console to the computer, all the LEDs will blink for a few seconds, so it's easy to see which ones have and which ones don't.
Cheers dj phatso! At least saves me worrying if the units working correctly. Wish it did them all though! Never the less ill just have to remember which ones ive pressed on the eq kills!
regards
Mark
Hello Fruity DJ,
On DJ Console Rmx, 16 buttons can light on:
2 x Pitch reset
2 x Beat Lock
2 x Sync
2 x Cue Select
2 x Cue
2 x Play
1 x Mic On/Off
1 x Source 1
1 x Scratch
1 x Source 2
Thanx MaxDJack
