error firmware herc...
error firmware hercules mk4
hi all, i decided to make this post because a few days ago install the firmware upgrade and from that time began to be console crashed within minutes of starting to use it, tell them that i use with traktor program. the truth that is not how to fix this from already thank you very much. i await answers.
Just so we understand properly, since the driver and firmware update:
- is your MK4 still correctly enumerated by the computer ?
- do you still have access to the DJ control Panel?
-do you confirm that the problem only occur when using Traktor ?
If this is all correct, what exactly do you mean when you say that the console "crash" after a few minute of use?
