hi i recently just bought the decks and am having a hugely frustrating time trying to get them to work! i install the drivers no problem with no errors but when i look at my devices the dj control mp3 e2 bulk driver is corrupted or missing. (code 39) which is not allowing me to use them!
im using windows vista home edition, 64 bit operating system, my proceser is a intel core 2 quad cpu q9300 @2.50ghz and have 4gb of ram
please help me!
are you using the latest driver (4.hdjs.2010), installed following the suggested procedure:
http://ts.hercules.com/download/sound/txt/dj_series_installation_pc_en.pdf
have you tried connecting the controller to another usb port/ using another cable ?
yes im using the latest driver and installed using the suggested procedure and have tried another usb port! i havent used another cable because i dont have one i expected the cable that came with it to be up to the task! my computer is up to the task it meets all the specs! got any other suggestions?
could you check the version of the file wdf01000.sys, which you will find at the following location
/* style definitions */
table.msonormaltable
{mso-style-name:"table normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"times new roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
c:windowssystem32drivers
normally, the file verison should be
font-size:10.0pt;
1.9.7600.16385
is that the case ?
i have the same problem with hercules dj console mk4 asio. i´ve already followed the procedures and nothing happens.
when i plug the output 1-2 the sound play nicely with windows media player.
the virtual dj shows a error message: error in the asio sound driver.
could you help me?
Are you using the latest driver (4.HDJS.2010), installed following the suggested procedure:
Have you tried connecting the controller to another USB port/ using another cable ?
Yes I'm using the latest driver and installed using the suggested procedure and have tried another usb port! i haven't used another cable because i don't have one i expected the cable that came with it to be up to the task! my computer is up to the task it meets all the specs! got any other suggestion's?
Could you check the version of the file Wdf01000.sys, which you will find at the following location
/* Style Definitions */
table.MsoNormalTable
font-size:10.0pt;
font-family:"Times New Roman";
C:\Windows\System32\drivers\
Normally, the file verison should be
font-size:10.0pt;
1.9.7600.16385
Is that the case ?
I have the same problem with Hercules DJ Console MK4 ASIO. I´ve already followed the procedures and nothing happens.
When i plug the output 1-2 the sound play nicely with windows media player.
The Virtual Dj shows a error message: Error in the Asio Sound Driver.
Could you help me?
