help dj control mp3...
help dj control mp3 le licence virtual dj
the key provided with the product is not activating the accaunt. can you help me out with a solution?
The DJControl MP3 LE does not include a license for Virtual DJ. Not sure which serial you are trying to use.
The controller is bundled with DJUCED 18, which does not require a serial number. If your controller is properly installed and detected by the computer, the software will be fully accessible.
If you own Virtual DJ Pro, please see this page:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=309&cid=10
