01/08/2010 10:57 am
hi all,
i have been using my hercules rmx console for a couple weeks now. i have one main issue. the pfl/cue select button is not working. i understand that to hear the side not currently playing through the main speakers i should use the pfl button and the volume is controlled on the top right corner with the cue/monitor balance as well. somehow this isnt working. i know my headphones work cause they work in my other audio devices.
02/08/2010 3:08 pm
see your other post on the subject:
http://www.herculesdjmixroom.com/en-us/forum/en-hardware/003759/?start=10
02/08/2010 3:08 pm
See your other post on the subject:
