hercules dj consol ...
hercules dj consol rmx controller and traktor pro
hey πŸ™‚ i just bought the herc dj con rmx controller, and i got tracktor pro, how can i map it out so everything is straight with the controller and i can get a banging set up with it and have no problems or irritations with it. and also i have anthor qustion. can i hook up a midi board to it like akai mpk key board up to it and still be able to mess around with that while on the mixer?
please help me out the best you can!
-sean
you can start with the basic profile available on the support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=5
the file contains a document explaining how to configure the rmx to use traktor and load the midi profile.
from there you can add as many controller as you want and modify it to your needs.
to learn how to use multiple midi controllers in traktor, i would recommend the frollowing tutorial:
http://www.djtechtools.com/2010/02/24/set-up-multiple-controllers-in-traktor/
You can start with the basic profile available on the support site:
The file contains a document explaining how to configure the Rmx to use Traktor and load the MIDI profile.
From there you can add as many controller as you want and modify it to your needs.
To learn how to use multiple MIDI controllers in Traktor, I would recommend the frollowing tutorial:
Dear DJ Phatso!
I've bought a Hercules RMX console not too long ago. Till now I've been using Virtual Dj but since so many people have recommended Traktor I've decided to try it as well. I've installes "Traktor Pro" this afternoon and everything works perfectly except one thing: the headphones. I can't hear anything in them πŸ™ I thing I've tried everything, but still no sound.
Would you be so kind and write some ideas, what can be the matter? In which output should the headphones be plugged? Is there any tricky setting that I might have overlooked? Maybe it's a typical problem... I've tried the manual on tc.hercules.com You adviced to another dj having the same problems, but I dudn't find the solution.
Thank youv very much in advance!
Greetings,
D
