hercules dj console...
hercules dj console air
ive bought a hercules dj console air 2 hours ago but i dont like the software, is there any other software like traktor or virtual dj? please help...
djd
p.s. i dont know if this was asked before, im new.
The DJ Control Air is a MIDI controller, and as such, will be compatible with any DJ software that allows you to configure MIDI controllers.
A MIDI configuration file for Traktor 2 is already available on the support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=287&cid=5
A similar file for Virtual DJ Pro should be available soon.
What about a midi map for another program like my Disco XT ??
Everything is possible. Before you mentionned it, I didn't even know about this software.
Usually, software companies contact our development department to get access to our controllers and provide native support for them in their application ( this has been the case for other such as Deckadance, Mixxx, Mixvibes, Ultramixer, etc).
 how about virtual dj software?
There is already a map for VDJ available on the support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=287&cid=10
I believe it should also be natively supported in their next update (unless they wait for v8 to include it).
