hercules dj control...
hercules dj control air bulk driver installation problem
hi everyone
today i bought a hercules dj control air mixing panel. i used the cd to install the drivers for the control panel and the djuced software. unfortunately, when i try to install the drivers, my computer is searching for possible drivers on its own windows update. when i change the settings not to search for them when i dont ask, he still does it when i try to install via the cd. my computer doesnt find the hercules dj control air bulk driver, nor does the cd install the appropriate bulk driver. the other (asio) driver is installed properly. what do i have to do?
the system of my computer is windows 7 home premium service pack 1, 32-bit operating system.
kind regards,
jonasty1
Please
1) uninstall the DJControl Air driver
Click on Windows > Control panel > Programs  Uninstall a program >
Select DJHERCULESMIX in the list, and click on Uninstall.
2) then install the last Hercules DJ drivers you find 2016.HDJS.1, they are here
https://support.hercules.com/en/product/djcontrolair-en/
but DO NOT ANSWER TO WINDOWS UPDATE POP-UP WINDOW, answering to it ruins the installation.
