hercules dj control...
hercules dj control air plus
hola, me gustaria saber como hacer para configurar el profesionaldj con dj control air plus , paso a paso para poder mezclar con este programa en lugar del que te dan por defecto al comprar la tabla.
gracias.
 hello, i would like to know how to configure the profesionaldj with dj control air plus step by step to mix with the program instead of the default you get to buy the table.
thank you.
If you tell us which other DJ software your which to use instead of DJUCED, I'm sure we can show you how to configure it to work with the DJ AIR +.
