hercules inplus 500...
hercules inplus 500 “hercules add-on”
hello,
wanted to know whats the mini din socket for "hercules add-on"?
Welcome on the forum.
Hercules add-on is an extension port to connect future (if any) add-on peripherals.
DJControl Inpulse 500 is the second Hercules DJ controller with this extension port (after DJC Inpulse 300) so once there is a sufficient installed basis add-on peripherals may be released, but it is still early.
Thrustmaster, game accessory manufacturer, had released steering wheels with add-on ports before Hercules, and after some times, they released complementary steering accessories connecting to the steering wheels add-on ports, as pedals, shifters and handbrakes. Add on ports saves space on USB ports. I do not mean you can connect a shiften of a hand brake on a DJ controller, but it shows the add on port is made for accessories released later.
I would like to thank you for the efforts you have made discussion with this forum, so if you are about to purchasing lowcost vpn so I have got the Cheap Dollar 1 VPN Deals blog which explain you can save your money.
