hercules mk2 and lo...
hercules mk2 and logic pro map problem
hi.i use hercules mk2 and logic pro 9.1.6 and i want to use it like a controller,but,i cant map up to one controls per time.for example.
i map cut off knob, of vangurd vst synth, to bass knob on a deck of hercules and i want to map pitch on any other knob,for example treble on deck a of controller.when i do this the cut off stops working and the two them knobs is mapped together.i fresh install snow leopard and logic pro and i have this problem,please help.thanks
The MK2 being a standard MIDI controllers, so you should normally be able to assign more than one control at a time. The problem seems to be with the way your are trying to program things.
I woud suggest reading the Logic user manual again regard MIDI configuration, or tutorial such as this one:
http://audio.tutsplus.com/tutorials/recording/how-to-configure-your-axiom-control-surface-with-logic-pro-9/
thanks for your reply,but i have already read this manual,i folliow it and problem is still here.
