hercules rmx help -...
hercules rmx help - software
hi, ive just started using my rmx, having been using a mk2 for the past 2 years or so and i was just wondering if you are able to use the software that came with the mk2 instead of that which came with the rmx (which is highly disappointing, when you got a much better bit of software with the inferior mk2)?
thanks for any help and sorry if this is a repost
the dj console rmx is supported by virtual dj from version 5.07 and higher, so using version 3.4.1 for mk2 is not be possible.
ok. cheers
one more question. is it possible to record a mix whilst using the limited edition of vdj? is there any software like audacity thatll help me to record (i tried audacity, but couldnt get it to work). cheers
indeed, the latest update (5.2.1) of virtual dj djc edition includes the possibility of recording your mix directly from the software ( a rec button now appears at the top of the interface).
you can obtain this update when registering on vdjs web site.
sorry, i meant to put for free in there somewhere
aha. excellent! thanks
The DJ Console Rmx is supported by Virtual DJ from version 5.07 and higher, so using version 3.4.1 for MK2 is not be possible.
ok. cheers
One more question. Is it possible to record a mix whilst using the limited edition of VDJ? Is there any software like audacity that'll help me to record (I tried audacity, but couldn't get it to work). Cheers
Indeed, the latest update (5.2.1) of Virtual DJ DJC Edition includes the possibility of recording your mix directly from the software ( a REC button now appears at the top of the interface).
You can obtain this update when registering on VDJ's web site.
