hercules rmx, insta...
hercules rmx, installations unable to complete - firmware problem?
hi all
i was just installing the drivers for my hercules dj console rmx, when someting went wrong. the buttons now keeps blinking and i can not finish the installation.
i believe it is a firm-problem. perhaps the firmware was updated wrongly.
now, when i try to reinstall the drivers, the installation freezes right after asking me to connect the console.
is it firmware-trouble? how do i reinstall the firmware? i see from other topics that people are asking for a manual regarding flashing the firmware manually - can anyone send me this?
thanks a lot.
regards
chris
hello! help me  please!  i have got a herkules dj mp3, but my flashing is not funkcion...send me somebody one pdf. book.this help me4 thank very! hey
my email adress:
message from the administrator / address removed
i have removed your address, it is not to disturb you but to save your email address from spams in case a spam robot scanning this forum detects your email. i have transfered your email address to a friend who will send you immediately the pdf documents on firmware update. in the future, if you want to give your email address, you should click on "members" and add people to your friends, and afterwards, once they have accepted your invitation via "my space" tab, you can exchange private emails with them.
hi,
i have the problem with the firmware update and all the light keep blinking
can someone sent me the pdf to reset the firmware plz??
im running it op a mac.
thanx
hello wendel,
why do you try to flash a dj control mp3? the firmware in dj control mp3 is not updateable, so of course you cannot rewrite the firmware of a dj control mp3, why do you want to do this operation which is possible only on dj console rmx?
dj jeffvv,
if you want a pdf guideline, you should invite one of the persons sendings the pdf guidelines (as jimmy b, cioce or me) via the private message system, and post in a private message the email address, asdescribed in the system administrator messages. your asking the pdf guideline wont help as long as we dont know your email address.
@ jimmy b.
hi dude...i added u as a friend. im after the "flashing your firmware" pdf docs. get back at me and ill send my email add.
thx
using vdj, on windows 7(x64) on my macbook pro and got the "flashing lights" scenario after updating to most recent drivers. i also got vdj loaded on my osx partition and that seems to be working ok.
@ jimmy b.
ive accepted it mate, so when ever you are ready just send me your email address via a pm.
@ jimmy b
i hope this isnt getting boring for you.... but im also looking for the "resetting firmware" pdf for my messed up console..
can you hep me out??
can you add me as a friend so i can sent you my adress via pm?
thanx!!!
hello solubel,
hercules has placed the pdf to reset the firmware on the technical support website.
go to http://ts.hercules.com/ , go to "updates and downloads", in "download" area, choose "sound cards" as product genre, "dj controllers" as product family, select the "dj console rmx" as product, and "manual / help file" as link, and the "manual firmware update guideline" includes the access to the pdf to reset the firmware.
hello solubel,
hi maxdjack,
thanks for your post. i am having the same problem with my rmx. i downloaded the pdf and followed the instructions to the tee (several times). i go right up to the end where it says that the firmware has been updated and you can now disconnect and reconnect the console.
when i do that, the leds on the rmx still keep flashing and the firmware is not updated. in the control panel it reads n/a in the firmware section.
please advise,
thanks
hello soulgroove,
to identify whether the issue lays in a computer setting or in the firmware of the rmx, did you try this on 2 different computers or only on 1 computer?
hey max,
2 different computers - a pc and a mac. i downloaded the instructions and drivers for pc and mac as well.
hi maxdjack,
i tried the procedure on yet another pc with similar results. does this mean that the rmx i have is faulty? should i go in for a replacement?
thanks
hello soulgroove,
i think you should
1 - install hercules last driver package
( http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=1
2 - if installing the last drivers doesnt solve your problem, call hercules technical support (number on http://ts.hercules.com/eng/index.php?pg=contact ) so that you test the firmware reflashing process with them on the phone and at the end of the flashing process, they can tell you if you did anything wrong or tell you the controller is faulty.
well.. me aslo. id be thankfull if you could send me this pdf.
[email protected]
windows xp sp2
windows vista; 7
virtul dj, hercules rmx
soulgroove ???
you can find it here
http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=6
It sounds like your firmware isn't installed problem
Get in contact with the Hercules Support, explain what is happening.
They will send you a pdf manual on how to re-set your firmware. I had to do it to mine. My first firmware took 4 attemps before it accepted it.
Hi Jimmy B
Thanks for the reply - I have written the support at hercules an email explaining the problem.
Hopefully they will help me out, so I can get the console working again.
Best Regards
chris (djlakrids)
Cool mate, you should be hearing from them soon.
If not, give me a shout and I may be able to pass the reset-manual on to you, Chris.
Hi again
Already heard from them - they e-mailed me the reset-manual and everything is working now with updated firmware!
Quite good customerservice! Also thanks to you, Jimmy B - for friendlyness and helping me out.
Regards
Chris
hi,
I have the same problems but i could'nt get the pdf file with the firmware reset process
Jimmy B, can you send me this by mail ?
Regards
Fred
Yes, no problem.
Could you post me your email address or send me a message with it in, and I'll get it sent to you
Manual sent to your email address fred Smile
Hope it works
Thank you jimmy,
unfortunately the problem is unsolved ...
the firmware flash worked but i still have  0 in the controller firmware field and only the MIC ON/OFF lights when i connect the usb cable
i have sound but the controller doesn't work
the rmx worked great since i bought it 2 days ago and installed it on my windows vista 64 system, but when i installed it on my xp pro partition (optimized for djing), the install seemed to be ok but i lost the controller function  and the leds on startup just after (only mic on/off)
i have sent and email to the hercule's support but i had no answer at this hour ...
I seem to be having the same problem with my unit.  Everything worked fine for a few months and then bam, flashing lights, tried the reinstall and it gets stuck just after reconnecting my RMX.  Now I can't uninstall the half installed drivers or fully reinstall them.
Jimmy, or anyone else, could you please send me the manual flash pdf as well?
Thanks
No worries mate, just send your email address by PM and I'll get a copy off to you my friend
i try with osx and windows to restart the firmware but all the computer don't hear my console!!!!
please help!
Can someone send me the info on how to reset the RMX?  It was working fine, tried to install it in a new computer - downloaded the patch from Herc website, now nothing but flashing lights, and none of my computers will recognize it!
Please Help!
DJ Nancy B
Thanks!
Hi Nancy,
Been helping you in the VirtualDJ forum. I got the firmware reset pdf. I will send you a PM via the VirtualDJ site about it, so please can you check your PM there
Cheers
Thanks Jimmy!  Not to sound dopey, but what/where is my PM?
Found it Foot in mouth
Sorry about that, should of said Private message instead
hello every body...
I'm a new user here in the hercules dj Mix Room... I'm in a big big trouble... I tryied to upgrade the firmware in my hercules dj console remix but there was a problem... and now there're flashing lights... I think there's a problem with the firmware... I called hercules support but the didn'd still answered me... and tomorrow I've a carnival party... and I'm desperate... is there anyone could help me with sending me the manual to RE-SET the firmware??? my private mail is
thank you so much... thank thank thank you
my best regards...
Message from the administrator / Address removed
I have removed your address, it is not to disturb you but to save your email address from spams in case a spam robot scanning this forum detects your email. I have transfered your email address to a friend who will send you immediately the pdf documents on firmware update. In the future, if you want to give your email address, you should click on "Members" and add people to your friends, and afterwards, once they have accepted your invitation via "My Space" tab, you can exchange private emails with them.
Could you please send me the manual firmware pdf file my email is ----------- thanks
I don't think an help will solve your problem, since obviously you didn't read this forum page, otherwise you would not have posted your email address in a public page.
auxilio help me please I got the same problem of alot of people withe the bloody firmware now my console mk2 is not working at all so please the only way to get it back to work is that somebody send me the reset- manual of the firmware please i need it URGENT I am dj from a club here in spain and I need it to fix it please JIMMY HELP ME ...dont know why the pdf file is not on the net or even here in the forum anyway hope to here from you soon...thanx for u help
Alright mate,
I'm sorry but I've only got the PDF manual for the RMX firmware reset. The firmware reset for the mk2 maybe different.
You could try this mate
http://ts.hercules.com/faqs/eng/her_eng_00268.pdf
Hello Darwin,
1) Please accept me in your space so that we can exchange emails so that I forward you the pdf file.
2) Please precise whether you are in XP or in Mac OS so that I send you the appropriate pdf file.
3) When you urgently need technical informations, you can contact Hercules Tech Support  by phone on the number listes on http://ts.hercules.com/eng/index.php?pg=contact, and by email on http://ts.hercules.com/eng/index.php?pg=email . Getting help requires that you precise your configuration.
i also have the same problem, but have received the pdf regarding flashing my firmware.
Only problem is, when i get the firmware updater up, it wont detect my device!
It detects it on my computer but not on the updater itself.
I followed all the instructions regarding holding the mic on/off button, does anyone have any solutions?
Dear Jimmy
I see that you may have the answer to my problem with a RMX too. Could you please send me the pdf manual to reset the firmware? I would be pleased if I could fix the problem...
I already tried to send a PM with my e-mail, but it doesn't work.
TIA
Rudi
I've accepted your friends request, so you should be able to PM me your email address.
And I'll get a copy sent to you
HELLO,,
I'm new here
I've been working with rmx since couple of weeks, all worked fine
but , i tried to install it on a laptop (xp) and didn't work anymore.
flashing lights and then nothing works...
I have a dj gig 2night , can somebody please helpme???
@hype83
Unbelievable. My rmx has been sent to the Netherlands (I live in Belgium), afterwards to the European headquarter in Germany . There, they said that my rmx was "irrevocable damaged".
Once home again, I thought that it could be the fireware. It couldn't be possible that such a thing, that costs over 300 EUR, broked up. So I looked over the internet, and here I found the solution. After a few attemps and rebooting my notebook, it worked.
Thank you for helping me!
Somebody, anybody send me the PDF document to reset my Hercules RMX firmware as the helpline keep sending me emails in german with links to their website and no PDF document. TIA
I just have the same problem with my rmx, it doesn't work on my macbookpro/PC etc.. Is it possible to send this pdf?
I have been searching for hours and hours trying and trying, pretty frustrating.. Maybe the pdf is going to save me(I hope so:D)
Cheers and enjoy dj'ing!!
well.. me aslo. i'd be thankfull if you could send me this PDF.
Hello Electronic whiplash and betes,
If you want to receive a pdf file from a member of the forum, you should:
1) send an invitation to the member from whom you expect the pdf file, so that you can exchange messages
- go on http://www.herculesdjmixroom.com/en-us/members/ select the member you want to invite and click on "add to my friends"
2) then, once the invited member has accepted your invitation, you should send a message precising
- your email address,
- that you want to flash the firmware of your console,
- precise which DJ Console you have
- precise your operating system (the flashing process is not the same in all operating systems).
Hi!
I did it, and i'm still wainting 🙂
Hello betes,
I have not received your invitation, so I have sent you one. Please accept it and email me your email address,  that you want to flash the firmware of your DJ Console Rmx, and precise your operating system (the flashing process is not the same in all operating systems).
hi,hi,
my email is SUPPRESSED  thankiu very much you are the best
Yes, no problem.
Having problem with Hercules RMX as well, I only speak/read english so I am having avery hard time navigating this forum site.
Can someone PLEASE send me the file to reset firmware?!? That seems to be the remedy for flashing lights. I have been able to install drivers "successfully" but the console still just flashes when connected.
email:
SUPPRESSED
(take out spaces)
PLEASE PLEASE PLEASE!!!  I need to have this working as soon as possible!!!
THANK YOU IN ADVANCE!
can someone please send me the information  on how to  reset the hercules rmx? i got it the other day  and tried to down load the  patch to fix the sound card error on the mac..and since then its been blinking no stop and is no longer even recognized  when its connected to the usb  it just blinks..can someone send me the pdf thing i keep reading about to reset  the device to  the settings it came woth  out the box....my email is SUPPRESSED  id gladly appreciate the help  form anyone  i have a gig fiday  i need the help as soon as possible
Hello munk, signu747, dj wanako,
I have just sent you at 6PM June 17th the pdf files you asked for.
if you don't get them, then your anti-spam filter prevents you from getting them. I think it is an unecessary risk to show your email address in the public pages of the forum instead of using the standard and normal process of sending private messages.
Hello! Help me  please!  I have got a Herkules Dj Mp3, but my flashing is not funkcion...Send me somebody one pdf. book.This help me4 Thank very! Hey
My email adress:
hi,
can someone sent me the PDF to reset the firmware plz??
thanx
Hello Wendel,
Why do you try to flash a DJ Control MP3? The firmware in DJ Control MP3 is not updateable, so of course you cannot rewrite the firmware of a DJ Control MP3, why do you want to do this operation which is possible only on DJ Console Rmx?
Dj Jeffvv,
If you want a pdf guideline, you should invite one of the persons sendings the pdf guidelines (as Jimmy B, Cioce or me) via the private message system, and post in a private message the email address, asdescribed in the system administrator messages. Your asking the pdf guideline won't help as long as we don't know your email address.
@ Jimmy B.
Hi dude...I added u as a friend. Im after the "flashing your firmware" pdf docs. Get back at me and I'll send my email add.
thx
Using VDJ, on Windows 7(x64) on my macbook pro and got the "flashing lights" scenario after updating to most recent drivers. I also got VDJ loaded on my OSX partition and that seems to be working ok.
@ Jimmy B.
I've accepted it mate, so when ever you are ready just send me your email address via a PM.
@ Jimmy B
I hope this isn't getting boring for you.... but im also looking for the "resetting firmware" pdf for my messed up console..
Can you hep me out??
Can you add me as a friend so i can sent you my adress via PM?
Thanx!!!
Hello Solubel,
Hercules has placed the pdf to reset the firmware on the technical support website.
Go to http://ts.hercules.com/ , go to "Updates and Downloads", in "Download" area, choose "Sound Cards" as product genre, "DJ Controllers" as product family, select the "DJ Console Rmx" as product, and "Manual / Help file" as link, and the "Manual firmware update guideline" includes the access to the pdf to reset the firmware.
Hello Solubel,
Hi Maxdjack,
Thanks for your post. I am having the same problem with my RMX. I downloaded the pdf and followed the instructions to the tee (several times). I go right up to the end where it says that the firmware has been updated and you can now disconnect and reconnect the console.
When I do that, the LEDs on the RMX still keep flashing and the firmware is not updated. In the Control Panel it reads N/A in the firmware section.
Please advise,
Thanks
Hello SoulGroove,
To identify whether the issue lays in a computer setting or in the firmware of the Rmx, did you try this on 2 different computers or only on 1 computer?
Hey Max,
2 different computers - a PC and a Mac. I downloaded the instructions and drivers for PC and Mac as well.
Hi Maxdjack,
I tried the procedure on yet another PC with similar results. Does this mean that the RMX I have is faulty? Should I go in for a replacement?
Thanks
Hello SoulGroove,
I think you should
1 - Install Hercules last driver package
2 - if installing the last drivers doesn't solve your problem, call Hercules technical support (number on http://ts.hercules.com/eng/index.php?pg=contact ) so that you test the firmware reflashing process with them on the phone and at the end of the flashing process, they can tell you if you did anything wrong or tell you the controller is faulty.
[email protected]
Windows Xp sp2
Windows Vista; 7
Virtul Dj, hercules Rmx
soulgroove ???
You can find it here
I m new here... I have a Hercules rmx and I ve got the same problem with LEDs blinking so i tried using the manual to update the firmware. I run the whole procedure but in the end of the update i got an error message saying: Error updating audio part: 0x00400009 ( Bulk transfer to the device failed during TUSBupdate).
Can anybody help me pls, i m really worries as noone seems to face the same prob.
Thank you
I seem to have the same problem in here. I have followed carefully all the manual to update the firmware but the buttons still blinked. I dont know what to do next.
I have sent and email to the support service but they didnt answer yet.
Do you know any other precedure to update it porperly??
I own an Macbook 2.1 Intel core 2 duo, 2 GHz, 1GB RAM operating with Mac OX Leopard.
Thanks I really apraciate your answers.
I have a problem with flashing led's on my Hercules RMX and I would try to reset the Hercules RMX to factory settings (not manual update from hercules support website). Can you please send me a manual??
Hello Cristian,
Please detail your configuration and drivers on your computer.
(for example : Dell Dimension 5150 - Core Duo 3 GHz - 2 GB RAM - Windows XP SP3 - Radeon X300 SE graphic card with 128 MB RAM - Hercules DJ Console Rmx with 2010_HDJS_2 drivers - VirtualDJ Pro 6.1 set with DJ Console Rmx in ASIO 16-bit 44.1KHz with output 1-2 set as master and output 3-4 set as preview - DJ Console Rmx control panel set on 6ms buffer size)
I tried on my laptop and on my PC and same thing. You can send me manual for XP 32 SP3 bit please.
Hello Cristian,
Which version of DJ Console drivers is installed on your Windows XP computer?
The firmware update software is completely changed in the last driver versions compared to older drivers, so one cannot write for you a procedure on how to update your firmware in an Rmx if you cannot provide an answer to this question.
Here are information on XP:
Package: 2.HDJS.2010
Firmware:1.0.6.31
Driver: 4.8.9.0
MIDI Map: Default
DJ API: 2.0.20.13
CPL: 2.0.6.10
Would you send me manual please?
Would you give me just a answer????
Mr Cristian,
1) Before giving you "just a answer????", we must write the procedure, and test it.
The pdf guideline is posted here.
2) I am not convinced you have any issue of firmware, I rather believe your problem lays in the USB port (in your computer or in the USB cable), or in the USB bus power: the USB power settings are listed here.
Thank you very much, but that didn't help at all. I have the sam issue like here: http://www.herculesdjmixroom.com/en-us/forum/en-hardware/004889/?start=0
I made everything on my laptop from ts.herculessupport page. Also when i connect my Hercules RMX on PC it's the same issue. The LED's are going crazy and in program is everything wrong. After few reconnecting of USB cable it works normally. I tried to chanege USB cable but it's same.
Hi i need help...i need the reset-manual...my rmx is flashing...i need to use it on saturday please help thanks
@DJ CoKrantz
Please start a new thread for your problem and also provide details of your system configuration and what seems to have happened as precisely as possible.
Page 8 / 9
