hercules rmx proble...
hercules rmx problem pre-listen in traktor pro 1.2
hello people
i set up everything thats needed to traktor pro 1.2 and hercules rmx work together.
latest drivers for rmx, midi map from the hercules page to the traktor pro 1.2 but,
everything works fine all the buttons, the problem is when i link the cue select in the console, it activates in the traktor headfones and so on, but i cant ear the pre-listen in any of the two outputs to the headfones.
i dont have minima ideia why, i tryed  pre-listen in virtual dj and it works fine is not problem of the console i guess.
i checked the traktor preferences i didint find anything related with the pre-listen. iam missing something ?
where is the problem, any one have a clue ?
thank you dudes
What to have to be sure is that the audio configuration of Traktor is similar to the configuration described in the document included with the TSI file.
If you are under PC, be sure to select ASIO mode in the Rmx control panel before launching Traktor. then your configuration should look something like this:
 In Output Routing:
Master Output
1 : output 1
2 : output 2
Monitor output
3 : output 3
4 : output 4
If you are using a MAC, the configurations is about the same, except that you don't need to make changes to the Rmx control Panel (as ASIO doesn't exist).
what to have to be sure is that the audio configuration of traktor is similar to the configuration described in the document included with the tsi file.
if you are under pc, be sure to select asio mode in the rmx control panel before launching traktor. then your configuration should look something like this:
 in output routing:
master output
1 : output 1
2 : output 2
monitor output
3 : output 3
4 : output 4
if you are using a mac, the configurations is about the same, except that you dont need to make changes to the rmx control panel (as asio doesnt exist).
