hercules rmx / trak...
hercules rmx / traktor pro duo
hey, so ive been using vdj7 for the longest time, but im now getting a midi fighter which uses traktor, so i want to get used to learning traktor, but i cant find any mappings i like, and i dont know how to make my own, properly (believe me, ive tried)
is there any mapping that anyone knows about that has the following, or similar?:
effect button1: loop in
effect button4: loop out
effect button 2: cut loop in half
effect button 5: increase loop size by double
effect button 3: set cue
effect button 6: delete cue
eq knobs: adjust eqs
eq kills: kill eqs
gain knob: filter
sync: beat sync
pitch reset: reset pitch
seek buttons: seek
cue select: play deck in headphones
pitch slider: effect slider
play/pause: play/pause
stop: stop
cue: jump to last cue & play from it
scratch: enable scratching
jog wheels: jog
volume sliders: volume
master volume slider: master volume
load deck a/b: load song into deck
browser buttons: up/down to find songs, left/right to go in/out of tree
thanks a lot
Have you tried the mapping available on the support site ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=5
As for learning about mapping, the Traktor user manual would be the first place to start for some information about the basics.
BTW, the MIDI fighter (and any other MIDI controllers) can be used with Virtual DJ.
Yeah I guess im just gonna have to try to map it myself again. And yes I know that it can but I dont have the effects/know how to map the midi fighter for vdj, its already set up for traktor which is why I want to switch, thanks.
