hercules web update...
hercules web updater by guillemot
hey everyone, for some some odd reason the web updater service cannot access the update file, does anyone else have that issue and did u guys solve it? thankx in advance
Can you try again?
It may happen because the server was not accessible at the moment you have tested it.
If you have still this issue, please precise your configuration:
- what is your operating system (in detail, for example: Windows 7 64-bit Service Pack 1, Mac OS 10.6.5 32-bit)
- have you installed your DeeJay TRIM in administrator mode
- firewall settings,
- antivirus.
You can always get the latest driver directly from the support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=60&pid=240&cid=1
yes same issue, im running w7u x64 sp1 build 6.1.7601......i have installed trim into admin mode, i allowed guillemot in firewall and antivirus......idk what seems to be the problem
What is your internet browser?
Do you get any error message?
well it works now all of a sudden....it has nothing to do with the internet browser setting or settings and plus its the updater itself.....if i try it later on  it might not work, so i figured that its prob on from 9-5 then punchout timeCool
