how to fix control ...
how to fix control air
hi guys i have an control air console which worked great until by accident, the usb cable terminals loose from the mainboard, i have been repaired but i am told it is only re-solder the terminals but without knowing the correct order you run the risk of burning the console. does anyone could help me if you know the correct order of the wires that connect to the mainboard inside the console? i would appreciate if anyone has a photo
Check it here:
https://www.dropbox.com/sh/i2wgpy45th096d3/xGotmWV2wd
Check it here:
Hello, i have encountered the same problem, please can you upload the pic again and send me the link. Thanks
will appear, to be enabled. Pick the Pokemon go app that tutuapp apk It has a good-looking amount of hacked as well as broken.
