issue when i try to...
issue when i try to recording tracks on my asus laptop and traktor 2/dj control air
hi guys!!
i have a issue when i try to recording tracks on my asus laptop and dj control air
when im using juiced.. its all ok.. i rec the set ..play.. and the sound is there..
on traktor 2 ..... i rec.. the file is created.. but whit no sound on it... that is strange...
can anyone help me pls???
juiced is a good software but have sync issues.... πŸ™
Hi Grim,
Did you check in Traktor's preferences => Mix Recorder => If the Source is in "Internal" ?
And for DJUCED, did you know that you can move the beatgrid to mix in a perfect sync ? click on the "BPM" at the right of the track display to open the panel, you'll see the Beatgrid panel πŸ˜‰
As a beta tester for DJUCED, I can say that the next update will resolve a lot of problems with Beatgrid detection.
And for the record, if a track contains a BPM in the id3tag, DJUCED, in 1.0.14 version, doesn't re-scan the file to detect the BPM... so right click on the Browser, then choose "analyze" to rescan the file.
This bug will not be more present in the next DJUCED update.
