loop and sample but...
loop and sample button dont work dj control air
hi guys, i recently try to use my old dj control air, and when i try to use the button to loop and for samples just dont work. i test on midi monitor and when i pushed get nothing. how i can fix that? may be activate loop function with shortcut on controller. thanks guys
Are you refering to the buttons at the center of the controller which are used to change the functions of the pad, or the pad themselves ?
1) Please fill your profile in clicking on "My Space"> "My Profile" http://www.herculesdjmixroom.com/en-us/account/informations/ .
- In "Hercules equipment in use", please check your Dj controller,
2) I think Phatso has guessed what you call "button to Loop or for sample": the buttons at the centre are mode buttons, not action buttons: they change the mode of the pads:
-set the mode in Loop, and your pads controls Loops,
-set the mode in Sample, and the pads controls samples.
