mapping dj control ...
mapping dj control air plus s series for virtual dj
i bought a console, hercules dj control airplus s series and i play with virtual dj pro 7.4 original bat the registretion code is allredy used and i want mapping file to conect my console with virtual pls tell me about this because i want to work with my console immediately. i have windows 7 home 64bit i3 core and 8 gb ram in my toshiba.
If you have registration issues with your VDJ Pro serial, you should contact Virtual DJ and they will gladly help you solve that problem:
http://www.virtualdj.com/contact/index.html
Once done, you'll be able to download the latest version (v7.4.3) which natively support the DJControl AIR+, without having to add a mapping.
