mx-4 problem. uk se...
mx-4 problem. uk service centre?
i purchased mx4 as b stock and it lasted less than a year but because i never used it for three months it ran out of warranty. i need to get it fixed and apparently it is the printed circuit board inside. is there a uk based service centre to get it repaired?
ive sent emails to france but not heard back and i need my unit sorted as ive got gigs to do, and using just the laptop is a pain when mixing.
h e l p ! ! !
You mean DJ Console 4-Mx?
What seems to be the problem you're having ?
Hello Ade,
1) The area to send emails for technical support is an unknown email address you have found in France, which you cannot know whether it in use any longer, the address you must use for technical support is the technical support address, it is on htpp://ts.hercules.com.
2) The first need is your describing your technical issue as no technical issue may be solved if you don't describe it.
