no sound when speak...
no sound when speaker is plugged
hi, i am sorry if there is already an answer for this but i just bought an hercules dj control instinct, installed the software but there is no sound both when it is plugged to a speaker or an headphone (its actually earbuds).
should i install any kind of drivers or does anyone know what the problem is?
thanks.
Indeed, you shoud install the latest drivers (2013.HDJS.2), available from the support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=306&cid=1
Be sure to strictly follow these instructions:
Once done, verify that your controller is correctly installed:
http://ts.hercules.com/faqs/eng/her_eng_00438.pdf
With your amplified speakers connected to the back of the Instinct, and your headphone to the front, launch DJUCED and verify that the default audio configuration is applied:
If this is correct, playing files, you should hear them through your speakers.
