pitch control slide...
pitch control slider not in correct position
hi .. wass up .. iam new to here . but iam using hdjc last 1 1/2 yrs sofar iam happy with that . it makes me happy every show... now i have a problem with my pitch slider,.. when my slider set to middle ( 0% pitch control) vdj 5.2 pro showing its in below the centre. not in correct posion ,, can anybody explain what is the wrong with that ..
hello djniwa,
have you tried if you meet the same issue with virtualdj djc 3.4 or with traktor 3 demo?
- if you meet the same issue, then the problem lays in your dj console mk2 (either hardware or firmware or driver),
- if you dont meet this issue with these other software, then the issue lays in the map of the dj console mk2 in virtualdj pro 5.2.
Hello DjNiwa,
Have you tried if you meet the same issue with VirtualDJ DJC 3.4 or with Traktor 3 Demo?
- If you meet the same issue, then the problem lays in your DJ Console Mk2 (either hardware or firmware or driver),
- if you don't meet this issue with these other software, then the issue lays in the map of the DJ Console Mk2 in VirtualDJ Pro 5.2.
