please !!! help me ...
please !!! help me !!!
cry
hello!
i have the hercules dj control mp3, cd with software and drivers, but i lost the disc packaging!
recently re-installed windows, installed the drivers for the hercules and the files of vdj (dj console)!
how do i restore serial key or where to find crack or something like that?
sorry for my english ! i live in moldova !
---------in russian language----------
привет! у меня есть hercules dj control mp3 , диск с программами и драйверами, но я потерял упаковку диска!
недавно переустанавливал ВИНДОВС, установил драйвера для ХЕРcУЛЕС  Ð¸ програмку vdj (dj console)!
как мне востановить serial key или где найти кряк или что то  Ð¿Ð¾Ð´Ð¾Ð±Ð½Ð¾Ðµ?
---------in roumanian language---------
buna! nu demult mi-am cumparat hercules dj control mp3,am cd-ul cu driver-uri si cu soft-ul special, dar am pierdut capacul! nudemult am reinstalat windows-ul , am instalat driverurile pentru hercules si programma vdj (dj console)!
cum pot restaura serial key-ul sau unde sa gasesk crack sau cum pot rezolva aceaasta problema!?
if youve already creaed a profile and entered your serial number on virtual djs web site, you could log in into your profile, which will diaply your serial number.
otherwise, you will need to contact their technical support:
http://www.virtualdj.com/contact/index.html
If you've already creaed a profile and entered your serial number on Virtual DJ's web site, you could log in into your profile, which will diaply your serial number.
Otherwise, you will need to contact their technical support:
