1
Posts
2
Users
Reactions
Views
27/02/2013 7:47 pm
hey guys, first post
got the tsi file off the website so i eventually got the controller working with traktor pro duo, but i cant pre listen. im currently using my alesis m1 active usb monitors plugged into my mac by usb.
i literally have no idea how to map the controller or anything, so all help will be greatly appreciated.
if you need any other information, ask away!
thanks!
josh
27/02/2013 8:04 pm
If you look at the PDF document included with the mapping, you'll see the audio configuration to be used with Traktor (as well as a description of the mapped functions).
Obviously, it is assigned to the DJ Instinct integrated audio interface, so you'll need to connect the Speaker output of the console to the back of your speakers to complete de setup.
