problem with rmx in...
problem with rmx in traktor
hey yall
i was reading the manual and  i have the hercules rmx....
it says "from the file menu, select audio setup. choose hercules dj console rmx asio as
audio device" and the thing is it does not have hercules dj console rmx asia as an option. what can i do about this to continue my installation?
if you look at the procedure again, you will notice that previously to launching traktor, you have to enable asio mode in the rmx control panel. otherwise, it will obviously not be available in the audio setup menu.
If you look at the procedure again, you will notice that previously to launching Traktor, you have to enable ASIO mode in the Rmx Control panel. Otherwise, it will obviously not be available in the Audio setup menu.
