problem with softwa...
problem with software
hello yall i bought a hercules djcontrol instinct about one month ago. since i got problems! when i start it works normally, but some minutes later i cant scratch no more! what can i do?? please help me =(
This problem usually occur because drivers were installed using another DJ console model, and you are now trying to install the new driver using another console (in this case an Rmx), and some file of the previous installation are not being updated.
The solutions:
1) Install the driver using the previous DJ Console (if possible) or simply connecting both consoles.
OR
2) Go to C:/Windows/System32/drivers folder and delete the following files:
- hdjbulk.sys
- hdjasiok.sys
- hdjmidi.sys
Once done, launch the installation again.
I do not have those files on my computer. I am running winsdows 8. I think I need an updated program or something.
Please help
So i made a mix with DJUCED 18 but i cannot upload the music file to YouTube or play it in any other DJ Software or when i copy it to my phone and play it it says "Sorry requested track not available" All the other DJ Softwares I've used dont have these issues.
-How can i fix all this?
