hi, just got my dj console mk4 and im having problems on trying to install it on my mac.
the requirements are mac os 10.5/10.6, but i have mac os 10.7.
is there any other way i can install the console on my mac? or is it just not made for it?
thanks
The OS given in minimum requirements are the ones that where available when the Mk4 was first released.
OS X 10.7 and 10.8 are fully supported using the latest drivers avilable from the support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=262&cid=1
I would also suggest getting the latest update for Virtual DJ (6.1.2), available from their website (the registration of your serial number will be necessary to obtain the file).
http://www.virtualdj.com/download/updates.html
