problems with the h...
problems with the hercules air mapping for traktor 2 pro?
this is the dj phatso mapping, i saw hes posted here before so i hope hell be able to asist!
i already have decent knowledge of how to map midi controllers, however, i have always had the same problem with the controller: when the right deck is playing, i cant scroll forward or backward on the left deck song using the jog wheel. but when left deck is playing i can scroll forward and back with the right jog wheel. when neither of them are playing it is fine. i am not sure why this is happening, maybe it might be to do with other mappings interfering with the hercules mapping?
hope i was clear enough..
thanks
So just to be sure we're on the same page:
- You are using the mapping file available from the support with which version of Traktor Pro 2?
- You've loaded the mapping as described in the included procedure document ?
If so, then the only other mapping present (from the menu DEVICE) is the default keyboard layout.
- Have you modified the mapping in any ways ?
- Is this problem noticeable only when Scratch is On, or it doesn't make a difference ?
Thanks for your reply
I used the mapping from the support page with Traktor 2.6 - it was traktor 2.0 but i updated. I had the problem on both. i'm pretty sure i followed the document correctly, changing the settings in the controller and the traktor software. I have maped my launchpad to hot cues, but i had the problem before i mapped this anyway. I have done a clean download and import of the mappings and i haven't modified them in anyway
When scratch is ON both the jog wheels work as they should - with the added scratching effect.
Another thing i have found is that when deck B is playing, I can seek through the playing track and the non playing track in deck A using the Jog wheels fine. When Deck A is playing i cant do either of these. This occurs when scratch is OFF
When neither of them are playing, everything works fine.
Thanks
Good catch!
Figured out what the problem was, and the corrected version has been uploaded to the support site.
Try it out and let me know.
Cheers, works perfectly now thanks!
