can anyone explain to me how i go about recording a 2 hour dj mix using all of my mp3 tunes using the rmx console and vdj. i am not using vdj pro i must add. grateful for some step by step "how to guides"!!!!
cheers
when you want to start recording your mix, click the rec button in the virtual dj interface (top right corner).
type the name for the file that will be created, and click on save to start recording.
the rec button displays a red dot during the recording session.
click the rec button again to stop the recording.
cheers ill give that a try!
When you want to start recording your mix, click the REC button in the Virtual DJ interface (top right corner).
Type the name for the file that will be created, and click on Save to start recording.
The REC button displays a red dot during the recording session.
Click the REC button again to stop the recording.
Cheers i'll give that a try!
