replacement crossfa...
replacement crossfader for rmx2
crossfader bent and broke on rmx2. how do i get a replacement crossfader?
You should contact Hercules technical support (contact on https://support.hercules.com/en/contact-en/ )  to replace it with
- either the same fader
- or the Innofader mini.
