hello all,
got a problem with my rmx. after a couple of hours djing, the volume drops part-way through tracks. it stays like this for about 30 seconds and then goes back to normal. the change is similar to when you cut out the bass and then bring it back in.
got a few more other smaller problems, but this is the biggest one so any help on this would be good first!
fyi i run traktor pro on a macbook.
cheers!
first, be sure to use the latest driver for your rmx (currently v1.77) and the latest update for your dj software (v1.2.3 for traktor pro).
you may also want to check the following document which explains ways to optimize your mac when using audio applications:
http://ts.hercules.com/faqs/eng/her_eng_00363.pdf
cheers im slightly behind on traktor updates so ill give that a go.
can anyone recommend a pre-amp? im playing my rmx (and the clubs mixers) into the red everywhere i go due to lack of volume from the unit which i think may be part of the problem.
when connecting to the amp or mixer, which outputs of the rmx are you using, rca or the 1/4 jack ?
the 1/4 have an outputs level of +4 dbu, which is used by pro level gear, so if you are using the rca and you feel the signal is too weak, you should switch to the 1/4 jack.
yes it is the 1/4" jack im using. its definitely louder than the rca, but still not quite up to the job.
thats rather odd.
what type of mixer and sound system is your club using ?
wherever i dj its always an allen & heath.
indeed , these are fairly common mixers, and i know xone 92 and xone 42 are often being used with out products, so im not sure why its not working for you.
First, be sure to use the latest driver for your Rmx (currently v1.77) and the latest update for your DJ software (v1.2.3 for Traktor Pro).
You may also want to check the following document which explains ways to optimize your MAC when using audio applications:
Cheers I'm slightly behind on Traktor updates so I'll give that a go.
Can anyone recommend a pre-amp? I'm playing my RMX (and the club's mixers) into the red everywhere I go due to lack of volume from the unit which I think may be part of the problem.
When connecting to the amp or mixer, which outputs of the Rmx are you using, RCA or the 1/4' jack ?
The 1/4' have an outputs level of +4 dBu, which is used by pro level gear, so if you are using the RCA and you feel the signal is too weak, you should switch to the 1/4' jack.
Yes it is the 1/4" jack I'm using. It's definitely louder than the RCA, but still not quite up to the job.
That's rather odd.
What type of mixer and sound system is your club using ?
Wherever I DJ it's always an Allen & Heath.
Indeed , these are fairly common mixers, and I know Xone 92 and Xone 42 are often being used with out products, so I'm not sure why it's not working for you.
