rmx2 crossfader pro...
rmx2 crossfader problems
greatings to all users
i have a dj console rmx2, and i use it with virtualdj 8.
on my last gig, i had some issues with the crossfader. couldnt reach the 100% on the right deck and sometimes jumping (on virtualdj).
i took the slider apart and cleaned it with wd40. the error seamed to go away, but i noticed some rust on the slider.
this weekend, the problem has returned.
i tested a new controller and vdj worked fine.
i want to replace the crossfader by a new one, but i dont feel like spending tons of money buying a "mini innofader".
where can i get the specifications or the model nuber of this xfader? the manufacturer is "alps".
thanks in advance.
best regards,
leopolo
The reference I know is RS4511SA6002.
I do not know if you can find it anywhere, as Alps may have dedicated this reference to Hercules, but you can find the reference RS45112A600J, which is so closed that I think you can use it.
Thanks for your help, i will search.
Best Regards,
Leo
Dear Leo,
Don't don't use WD40 for cleaning pot meters, you gonna destroy them. You only get more problems because you remove resistance layer.
Also, don't use kontakt 60.
For safety for the layer use tuner spray, this liquid is safe, evaporated at all and leave nothing behind.
Best Regards.
