sensor air without ...
sensor air without lkeeping pressed pad
hello, im gonzalo from argentina. id like to know if there is way to use effect parameter on air without keeping pressed the pad button. id like to use it just pressing it. the strenght of press adjusts volume and without keeping pressed pad, regulate effect parameter.
please man, if is there a possibility or mapping let me know.
thanks for reading, ill appreciate a solution.
gonzalo
Well, as far as i know you need to keep it pressed while using the effect. You can always try to get some more info on the DJuced forum:  http://www.djuced.com/djuced/
Also, there is some info in the manual that you might find helpful:
" You can control the effects in the DJUCED graphic interface:
- Run or stop an effect by clicking on the effect button.
- Load another effect in the slot by clicking on the effect’s blue triangle: this displays a menu in which you can select the effect to load in the slot.
- Modulate the last effect loaded with the 2 rotary buttons on the right of the rack of effects.
You can also control the effects using the DJ Control AIR’s control surface:
- Activate effect mode by pressing the Effects button in the center of the controller.
- Run or stop an effect by pressing the pad (1 to 4) where the effects are loaded.
- Modulate the first setting of the effect according to the velocity at which you hit on the pad.
- Modulate the second setting of the effect by keeping your finger on the pad, and moving your hand over the proximity sensor (within 4 inches / 10 cm).
- Change the effect loaded on the pad by keeping your finger on the pad, while using the (Up) and (Down) buttons (located around the button labeled Effects) to browse through the effects list. "
