sound glitches > re...
sound glitches > resolution
hi guys,
i know that from previous times when i get glitches or unstable audio i close traktor and change the audio buffer size in the hercules control panel and make 1 or 2 other changes it normally comes right.
do you have any documentation or explanation of what these changes do? like changing buffer size does it worsen the audio output in anyway? pros vs cons of doing this?
i seem to remember some documentation or content helping users understand what all this means but i cant find it anymore..
please help..
thanks
matt
here is a good explanation :
http://support.apple.com/kb/ht1314
if you use the console under asio mode you can tweak the latency. try a bigger value (30ms for example) and descend until a bit before it starts glitching again. depending on your computer you could get a really fast response (small delay) without having glitches in the sound.
Here is a good explanation :
If you use the console under ASIO mode you can tweak the latency. Try a bigger value (30ms for example) and descend until a bit before it starts glitching again. Depending on your computer you could get a really fast response (small delay) without having glitches in the sound.
