sound problem with ...
sound problem with dj 4set
hello all
just buy the dj 4set but after several instalations , and some forums , im here....
the problem is that the sound comes out bad......he coups and retourns and that makes me crazy i have intall the software cd drivers abd vdj le.......my pc is  vaio i5 with 6 gb of internal memory and im runing win 7 64 .......
can any one help me please........
hellllllpppppp please........
I am not sure of what you mean in "he coups and retourns", but if you mean the sound playback cuts, then you have 3 possible explanations:
1)  you have let the wifi: you should disable the wifi when DJing,
2)  you have let windows USB default setting which cuts the power on the USB, which causes noise in the US audio: you must disable this (stupid) Windows settings
- Right click on MY COMPUTER icon on your desktop and select Properties.
- Select the Hardware tab (Windows XP), or in the Left–hand section (Windows Vista), click on Device Manager.
- Under Universal Serial Bus Controllers, Double-click on ont the first line USB root hub.
- In Properties > Power Management tab, uncheck "Allow the computer to turn off this device to save power".
- Repeat the same process for all lines USB root hub,
3) You have set a too short ASIO buffer size in Windows: close VirtualDJ, open the DJ 4Set control panel, set the audio mode in ASIO and set a bigger ASIO buffer size (the best ASIO buffer size you can get, if your computer is well set, is 2ms; if your computer is not well optimized you may have to go up to 10ms).
The optimization guidelines for DJing in Windows are here.
Maxdjack first thanks for spend your time to reply my msg.......;)
I have try all 3 explanations u give me.......i can say that the sound is betterr but it bugs the same way......sometimes even looks like the pich goes a little slow and retourns ...and he coups and retourns....and i have some little cracks on the sound....im starting to hate the dj 4set.......the pc i just buy it at 3 mouths....and its has some good specs......even try to download the ASIO for all....but i cant get it to work......affffff......very sad......
πŸ˜‰
