1
Posts
2
Users
Reactions
Views
12/12/2014 5:38 pm
hello,
i bought dj control mp3 le. i use an external sound card http://www.i-tec.cz/?t=3&v=123, windows 8.1, asus computer with 64-bit. the problem is that the program duject 18 and 8 virtual dj is not set to output to the loudspeakers and the other on listening to headphones. not play a single output and a second listen. how do i configure the program to work properly?
thank you
12/12/2014 6:30 pm
The following document should help you:
http://ts.hercules.com/faqs/eng/her_eng_00401.pdf
http://ts.hercules.com/faqs/eng/her_eng_00462.pdf
Although, your external soundcard is different, the configuration remains the same.
