1
Posts
2
Users
Reactions
Views
13/01/2014 10:13 pm
hi,
im trying to learn to scratch but im struggling a bit with the best settings on traktor and on my hardware settings.
what would you guys recommend?
hercules control panel - sensitivity: normal / 1/2 / 1/4 / 1/8
traktor: rotary sensitivity? rotary acceleration?
thanks in advance guys for your feedback!
13/01/2014 10:41 pm
Are you using the Traktor .TSI profile from the Support site ?
If so, I would recommend using the default settings (which have been optimized for this use) and start by getting acquainted with the way the hardware work.
You'll find that moving to other controllers or even turntables, you'll have to rely on your ear and feeling to adjust to the hardware (as sensitivity settings may not be available).
