traktor pro 2.1.2+ ...
traktor pro 2.1.2+ hercules controler mp3 e2
for some reason i cant scratch with the controller and crossfade and turn up and down the voulme can someone help please
Could you be a little more specific ?
Are you using the MIDI profile available on the Hercules support site ?
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=61&pid=241&cid=5
If so, have you read the included document explaining how to enable and use scratch (hold the CUE button + turning the jog )?
yes i used the file its just that i cant scratch when amplaying the sond instead the beatgoesfaster the problem wth the crossfader was that i didnt have my audio set up but yeah i just can scrath in the midlle of a song i have to stop the sondg and scratch
If the SCRATCH button is Off , then the jogwheel will be used for pitch bend (which makes the beat goes faster).
If the SCRATCH button is On, then the jogwheel will be in scratch mode, and hold CUE + using the jogwheel will allow you to do it anywhere in the song.
Keep in mind that the MP3 e2 doesn't have touch sensitive jogwheel, so Traktor can't know when your are touching the wheel, so adding a button to let it know that you when you push it you want to scratch was necessary.
