traktor pro problem
traktor pro problem
hello,
i have followed the guide to setup traktor pro with the hercules rmx controller.
when i have it set on the asio i get no output and also the controller does nothing, if i change in traktor to use my pcs internal sound card as the audio device the sound starts to play and also the controller works perfect.
not sure but traktor does not like it when i set the audio device to hercules dj console remix asio
any ideas
out of curiosity, does virtual dj included with the console work, since it also uses asio ? if it does, at least we can rule out certain possible issues.
are you using the latest drivers ?
as for traktor pro, you also have the latest upate ( v1.02)?
i got a feeling its something to do with my pc because when i try and use vdj with asio it does not work either, i was using the traktor 1.01
got a decent and recent system ?  laptop or desktop ?
you might want to take a look at this guide. there is a lot of things you can do that could improve the performance of your computer:
Out of curiosity, does Virtual DJ included with the console work, since it also uses ASIO ? If it does, at least we can rule out certain possible issues.
Are you using the latest drivers ?
As for Traktor Pro, you also have the latest upate ( v1.02)?
I got a feeling its something to do with my pc because when i try and use vdj with asio it does not work either, i was using the traktor 1.01
Got a decent and recent system ?  Laptop or desktop ?
You might want to take a look at this guide. There is a lot of things you can do that could improve the performance of your computer:
