treble knob problem...
treble knob problem *hercules rmx*
hello, i really need some help please couse this issue is really annoying. ive been using the hercules rmx for some time now and never had any problem. ive allways been very carefull with it, but yesterday, i used the left side treble knob and it went crazy. its like i just rotate the knob a little bit and it turns all the way up, and then i rotate the knob again just a little bit and it goes back to the middle, just acting crazy.
i use traktor 2 with a special mapping i found on hercules web page, but i dont think its a software problem couse i didnt move anything since the first time i mapped it.
has anyone ever had this problem? if i cant fix this i would need to buy a new controller πŸ™
thank you very much.
Can you test if you get the same issue in VirtualDJ?
Hi!, thank you for answering.
K, I tryied it on Virtual DJ in my macbook, also tryied it in another computer with Traktor and VDJ, I tryied with another USB cable, different USB ports in both computers and it happens the same thing everytime.
It happens mostly if I push it a little bit when I rotate the knob πŸ™
Any ideas? πŸ™ Ty
Hi djcrawser,
You also might wanna test the midi signals it puts out:
http://ts.hercules.com/faqs/eng/her_eng_00352.pdf
See if it gives the correct signals, knobs should have a value from 0 till 127.
Greetz
TheCause
Hi TheCause, thank you for answering me.
K, i just used MIDI monitor. At first I used de knob slowly and soft and it went perfectly... from 0 to 127 without no skipping. but then I rotated the knob with normal strength and it was going 0,1,2,3,58,20,70,12,127,0,124,13 (crazy)... so I think it means that actually the knob is not working as it should.
Now, how can I fix this? πŸ™ thank you very much.
Yeah that sounds like a problem with the knob itself, if you still have any warranty on it this is the time to use that.
You could also try to contact hercules tech support to see if they have this part available.
Greetz
TheCause
