using effect parame...
using effect parameter with sensor air, without keeping pressed the pad.
hello, im gonzalo from argentina. id like to know if there is way to use effect parameter on air without keeping pressed the pad button on djuced. id like to use it just pressing it. the strength of preassure adjusts volume and without keeping pressed pad, regulate effect parameter.
please man, if is there a possibility or mapping let me know.
thanks for reading, ill appreciate a solution.
gonzalo
Currently , it is not possible to modify the MIDI mapping of the console in DJUCED.
